I am not sure why layers are being added twice here?import arcpy from arcpy import env import pythonaddins class ButtonClass1(object): """Implementation for add_Layers_addin.button (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): #set the map document reference mxd = arcpy.mapping.MapDocument("CURRENT") #set the dataframe reference using the map document and the first data frame in the list df = arcpy.mapping.ListDataFrames(mxd)[0] #set the layer reference using the map document reference and the first layer in the list of layers layer1 = arcpy.mapping.ListLayers(mxd)[0] symbologyLayer = r'G:\Texas\Potter-Randall\Database\Ownership.lyr' #create a search cursor to get relevant information about a parcel sc = arcpy.SearchCursor(layer1) #for loop to get the selected data for row in sc: #select the relevant fields to be put on the map ap = row.getValue("MAP_NUMBER") addLayer = arcpy.mapping.Layer(r'G:\Texas\Potter-Randall\Database' + '\\' + str(ap) + '\\' + str(ap) + ".gdb" + '\\' + str(ap)) arcpy.ApplySymbologyFromLayer_management (addLayer, symbologyLayer) arcpy.mapping.AddLayer(df, addLayer, "TOP") #zoom to selected features df.zoomToSelectedFeatures() #refresh the active view arcpy.RefreshActiveView() #delete map, layer and dataframe variables del mxd del layer del df del ap del sc del row
