I am making a survey using Connect that will be solely used on mobile browsers (since it is a crowdsourcing survey and they will not have the app downloaded). When you make a survey using the web tools instead of Connect there is a checkbox to "Ask for device's location when opening this question" which is exactly what I need. However, there doesn't seem to be an option to do the same when it is built in Connect. Without this option the user has to click the crosshairs button to go to their location and pin it, which can be confusing in a situation that needs quick response.
I am also looking to hide the map (I already hid the input) if that's possible to limit user confusion but understand if this isn't possible on the browser surveys.
