The following steps explain my workflow to create a Feature Layer from a Spatial Dataframe. Also the coordinates should be projected in another coordinate system.
1. Create a point located in Munich with WGS 84 coordinates and add it to a list.
dictSpatialReference <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN>
dictPoint <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN>
x <SPAN class="operator token">=</SPAN> <SPAN class="number token">11.575442</SPAN>
y <SPAN class="operator token">=</SPAN> <SPAN class="number token">48.137141</SPAN>
wkid <SPAN class="operator token">=</SPAN> <SPAN class="number token">4326</SPAN>
dictSpatialReference<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> wkid
dictPoint<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"x"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> x
dictPoint<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"y"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> y
dictPoint<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> dictSpatialReference
pt <SPAN class="operator token">=</SPAN> geometry<SPAN class="punctuation token">.</SPAN>Point<SPAN class="punctuation token">(</SPAN>dictPoint<SPAN class="punctuation token">)</SPAN>
listGeometries <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
listGeometries<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>pt<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>2. Create a pandas dataframe with aditional information.
d <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Marienplatz"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'city'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Munich"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">}</SPAN>
df <SPAN class="operator token">=</SPAN> pd<SPAN class="punctuation token">.</SPAN>DataFrame<SPAN class="punctuation token">(</SPAN>d<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>Next a Spatial Dataframe is created and a Feature Layer is published. The coordinates should be transformed in the DHDN_3_Degree_Gauss_Zone_4 coordinate system (WKID: 31468) that is a projected coordinate system for Germany. To achieve this, two different ways are implemented.
1. Project the geometries, create a Spatial Dataframe and publish a Feature Layer.
listGeometriesProjected <SPAN class="operator token">=</SPAN> geometry<SPAN class="punctuation token">.</SPAN>project<SPAN class="punctuation token">(</SPAN>listGeometries<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4326</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">31468</SPAN><SPAN class="punctuation token">)</SPAN>
spatialDataFrame <SPAN class="operator token">=</SPAN> fs<SPAN class="punctuation token">.</SPAN>SpatialDataFrame<SPAN class="punctuation token">(</SPAN>data<SPAN class="operator token">=</SPAN>df<SPAN class="punctuation token">,</SPAN> geometry<SPAN class="operator token">=</SPAN>listGeometriesProjected<SPAN class="punctuation token">)</SPAN>
spatialDataFrameLayer <SPAN class="operator token">=</SPAN> spatialDataFrame<SPAN class="punctuation token">.</SPAN>to_featurelayer<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"MarienplatzProjected"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The coordinates are projected correctly and the Spatial Dataframe is created. The result of the "to_featurelayer()" method is this error message.
Exception Traceback (most recent call last)<ipython-input-61-74d83f9ecb21> in <module>()----> 1 spatialDataFrameLayer = spatialDataFrame.to_featurelayer("MarienplatzProjected") 2 #spatialDataFrameLayer = spatialDataFrame.to_featureset()~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis
\features\_data\geodataset\geodataframe.py in to_featurelayer(self, title, gis, tags) 899 raise ValueError("GIS object must be provided") 900 content = gis.content--> 901 return content.import_data(self, title=title, tags=tags) 902 #---------------------------------------------------------------------- 903 def set_geometry(self, col, drop=False, inplace=False, sr=None):~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis\gis
\__init__.py in import_data(self, df, address_fields, **kwargs) 2345 if target_sr is not None: 2346 publish_parameters['targetSR'] = { 'wkid' : target_sr }-> 2347 return item.publish(publish_parameters=publish_parameters) 2348 return 2349 elif isinstance(df, pd.DataFrame):~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis\gis
\__init__.py in publish(self, publish_parameters, address_fields, output_type, overwrite, file_type) 5426 except: pass 5427 else:-> 5428 serviceitem_id = self._check_publish_status(ret, folder) 5429 return Item(self._gis, serviceitem_id) 5430 ~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis\gis
\__init__.py in _check_publish_status(self, ret, folder) 5660 #print(str(job_response)) 5661 if job_response.get("status") in ("esriJobFailed","failed"):-> 5662 raise Exception("Job failed.") 5663 elif job_response.get("status") == "esriJobCancelled": 5664 raise Exception("Job cancelled.")Exception: Job failed.2. Create a Spatial Dataframe with the WGS84 coordinates and use the "reproject()" method.
spatialDataFrame <SPAN class="operator token">=</SPAN> fs<SPAN class="punctuation token">.</SPAN>SpatialDataFrame<SPAN class="punctuation token">(</SPAN>data<SPAN class="operator token">=</SPAN>df<SPAN class="punctuation token">,</SPAN> geometry<SPAN class="operator token">=</SPAN>listGeometries<SPAN class="punctuation token">)</SPAN>
spatialDataFrameProjected <SPAN class="operator token">=</SPAN> spatialDataFrame<SPAN class="punctuation token">.</SPAN>reproject<SPAN class="punctuation token">(</SPAN><SPAN class="number token">31468</SPAN><SPAN class="punctuation token">,</SPAN> transformation<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">,</SPAN> inplace<SPAN class="operator token">=</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
Using the reproject method does not change anything and the coordinates and spatial reference system are still WGS84.
How can I project a Spatial Dataframe and publish the data with the chosen coordinate system as a Feature Layer?
rsingh-esristaff
