I recently downloaded a survey initially publish in 3.7 (think) and republished it in 3.9. Now that I've done this, all of the select_one questions are acting like select_multiples (See pictures below) and the Relevant logic isn't working either so the hidden relevant question are not displaying. It should be noted that in the display window of Survey123 connect, everything appears to work correctly, it even works fine in the blank webform. When attempting to edit a record (and add a new one) using a URL Such as
https://survey123.arcgis.com/share/0b42c74c97d6480cbdfb27ee5dc5b20a?mode=edit&objectId=2265
This issue manifests. It also works properly if a survey already exists for the record being edited. This only happens when creating a new survey for a related record that does not have a survey already filled out for it.
I have tried switching the objectId string to globalId and the problem still persists.
Update : Republishing the survey from an older version of Connect, v3.7, eliminates the problem. This is still an issue as the survey is still under review an in the development process, so updates are still being made so version locking is very inconvenient.
