Hi all!
I'm looking to define the display field of the hosted feature layer that gets created when publishing from Survey123 Connect to Portal before the publishing actually occurs. The reason I'm trying to do this is even when my web map's search settings point to a specific attribute field from that layer, when a search occurs in an Operations Dashboard, it still tries to point to the Object ID field, which is the default display field.
Any help or advice would be greatly appreciated. Thanks!
- Mark
