We have a custom print widget which was developed using Export Web Map task and shared as a geoprocessing service to the server from ArcMap. This print widget is customized to have only 11*8.5 and 24*36 layout sizes. The base maps are printed fine with the 11*8.5 size, but when I use 24*36 layout it is completely messed and it misses tiles around the map. I saw a thread explaining that ESRI Dev team is working on this issue (way back in 2017). Are there any new updates or fixes for this so that we can print the vector base
