I am replacing square brackets by round brackets with help of a python script - works perfectly.
But I also want to replace a single word by another word (Cruise -> Campaign): nothing happens.
Here is the part of the script:
r <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>reader<SPAN class="punctuation token">(</SPAN>t<SPAN class="punctuation token">,</SPAN> delimiter<SPAN class="operator token">=</SPAN><SPAN class="string token">"\t"</SPAN><SPAN class="punctuation token">)</SPAN>
all<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
header<SPAN class="operator token">=</SPAN>r<SPAN class="punctuation token">.</SPAN>next<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#arcpy.AddMessage(header)</SPAN>
<SPAN class="keyword token">for</SPAN> fields <SPAN class="keyword token">in</SPAN> header<SPAN class="punctuation token">:</SPAN>
fields<SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Cruise"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Campaign"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="comment token">##not working</SPAN>
fields<SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"["</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"("</SPAN><SPAN class="punctuation token">)</SPAN>
fields<SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">")"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
