I have a queryTask based on the URL of my featureLayer. This layer has 508 features in this layer. My maximum record count on my service is much higher than that, to accommodate another layer with more features in it. I'm using AGS 10.2.2 and Advanced Query Support says 'true'.
I'm using this queryTask as the source for a dropdown list, so I need to get just the distinct values from my AgencyAcronym field. My queryTask executes, but instead of the 18 distinct values for this field, I'm still getting 508 features returned. I'm having to run these through another function to remove the duplicates and I don't think I should have to do this. I've tried a where clause of '1=1', because I want to check all records, but that doesn't make a difference, I still get all 508 features.
I have my queryTask set up as:
//populates the pick list searching state facilities by agency
populateBuildingList: function(){
app.buildingAgencyList.length = 0;
var queryTask2 = new QueryTask(app.buildingLayer.url);
var query = new Query();
query.where = "AgencyAcronym is not null";
query.outFields = ["AgencyAcronym"];
query.orderByFields = ["AgencyAcronym"];
query.returnGeometry = false;
query.returnDistinctValues = true;
on(queryTask2, 'error', function(err){
console.log('error populating building list: ' + err.error)
queryTask2.execute(query, lang.hitch(this, updateBGridHandler));
function updateBGridHandler(results){
console.log('results of updateBGridHandler :' + results.features.length + " records" ); //all 508 records returned.
arrayUtils.forEach(results.features, function(feature){
var agencyName = feature.attributes.AgencyAcronym;
agencyName = agencyName.replace(/^\s+|\s+$/g,'');
app.buildingAgencyList.push(agencyName);
app.buildingAgencyList.sort();
var sortedList = common.sortAndRemoveDuplicates(app.buildingAgencyList); //a function I'm having to use because the values aren't unique
var data = arrayUtils.map(sortedList, function(itm, idx){
return {
"id": idx,
"name": itm,
"value": itm
var currentMemory = new Memory({
data: data,
idProperty: 'id'
app.agencyDropdown.set("store", currentMemory); //a grid created earlier
app.agencyDropdown.sort('name');
