I'm trying to use pulldata in a way I'm not sure it can be used.
In this instance, I'm trying to pull three rows from the table based on a single attribute.
Background - pull info on transformers installed in a location by map number. Each transformer has unique info on table, but there may be more than one transformer at a given map number.
So if the table has three transformers consecutively in rows, but they have the same map number, can I get Survey123 to pull each line into the form.
