With the inbox functionality of Survey123 it is possible to make existing surveys available (and editable) for users in the field (using the Survey123 app). The surveys for download can be filtered with a where clause in the survey definition. If I want to change the filter I need to re-publish the survey.
We are now looking for a way how the user in the field can filter the surveys he wants to load down for editing (e. g. based on a project number). The survey definition itself should remain untouched, re-publishing should not be necessary.
Is there a way to do this or are there plans to implement a download filter option for the field user?
Thank you very much, best regards,
Jürgen
