Need ability for realtime python script to perform field calculations on multiple fields in a record when that record is new or updated.
Looking for equivalence to SQL triggers or form departure actions - Example - a feature field for a utility pole such as "Serial number" is added/updated in the field from a asset tag. This would trigger a script to fill in other fields for that record. Currently I do this with a nightly script. Realtime updates would allow the field worker to enter a tag number and submit the record, and view results to help confirm accurate entry of "Serial number". Field data entry (Collector with a touch screen in the sunlight) is prone to error. If the realtime "serial number" field calc returned a "material type" =Steel, and it was a wooden pole, it would let the field worker see that the "Serial number" was incorrectly entered. Using a prepopulated related table does not work, since entries may be deleted or keys nulled by edits of the feature class.
