I am having some trouble with the measurement widget that I can't seem to get to the root cause of. Hoping someone might have seen this issue before.
I have the search widget and the measurement widget in the same app and I am getting some weird behavior.
1) If a user uses the search widget to return a result.
2) and then pans to a different area on the map.
3) and then uses the measurement tool to measure a distance or an area. When the user clicks the second position using the measurement tool. The map pans back to the area of the original result returned by the search widget.
This behavior can be seen here.
Thanks for any help.
Rich
