Dear ESRI community
I'm busy implementing the Arc Hydro Geodatabase XML schema and have come across a problem that I need assistance with. The Arc Hydro Data Model has been saved as a XML Schema. I have imported it into a newly generated File Geodatabase and then defined the local projection based on my study area. The problem that I have is that the Domain, Resolution and Tolerance is not being updated and when I try to add features through an edit session I receive the following error message.
"The Create Feature task could not be completed. The coordinates or measures are out of bounds"
Any assistance to import the following schema and set the projection which will update the Domain, Resolution and Tolerance will be appreciated.
Regards
Peter Wilson
