I have a long list of integer fields (25 fields) from where I want to calculate the total in the end. I have put all as default=0 to make sure that no "NULL" value is disabling my calculation. When I now use the "tab" to jump from field to field the cursor is placed after the default 0 so the user always has either to go manually before the zero or has to delete the zero before starting to type his own value. I would prefer to have the whole default value selected when reaching the field so it would automatically be overwritten when I start typing. Is there a way to do that? Or is there a different way to make sure I can use the field for my calculations? I was just thinking of using if(${field}!=NULL,...) but that would mean I have to do a 25times nested "if...", right? There must be an easier way...
Thanks for your input!
