I am trying to create a survey of asset inspections from an existing asset feature service with the inspections in a related table. I don't want to edit the features, just add/edit related inspections.
Ismael Chivite indicates in this 2017 UC workshop video that Survey123 Connect can be used to create tables in ArcGIS Online. Survey123 for ArcGIS: Advanced Topics - YouTube
Using Survey123 Connect, can you create a survey from an existing feature service, then add a set of repeat questions, and then publish the survey to create the related table in the feature service?
I have seen the instructions to delete the questions from the feature service, delete the begin repeat and end repeat, and set the form_id in the settings, but whenever I try to publish the survey, it says that the related table is not found. Of course, it does not yet exist against the feature service because I thought Survey123 Connect would create it. Do I have to create the related table myself?
