Before we had a test environment : 'a normal ArcGis'. Now we are on a portal.
Before it was possible to have a survey 123 , with signature as image ( so attachment). It was possible to use the 'report' function and as a result it showed the signature on the word document.
Now on the portal this doesn't work anymore ....
Could this be the reason :
Feature report templates—Survey123 for ArcGIS | ArcGIS
Limitations
- Attachments are not supported using the Survey123 website with ArcGIS Enterprise
How can I solve this, or what is a work around ?
Thank you
