How do I select points that are within a 5 metre radius of points in a different layer and extract the attributes from those points? So ideally I want to produce a table that has a column of all the points from the source layer, with columns for attributes of the points that fall within the buffer of the source point. Most points will only have one point within the buffer but there might be occasions where more than one point fall within the buffer.
Thanks!
