Hi All,
Currently we are using Collector and S123 to capture our field data. If our crews are working in an offline area we are getting duplicates created on the same work task. This is happening because the symbology isn't being reflected in Collectors map.
Is it possible to check the 'instance_name' in the 'Sent' folder on the local device (ipad) for a match with a unique_id passed from Collector? If a match is found i would like to display a note on the survey explaining that a record has already been created and giving them the option to edit it.
Mick
