Hi
This follows on from a question I had earlier about issues I was experiencing in trying to create a local copy of data for editing. I suspect it is to do with field aliases (which are sourced from the Label column in XForms).
I've made some changes to my Xforms document and republished the survey (deliberate changes so as to not force re-creation of the feature service). The changes are primarily to the Label field to shorten it up and remove any special characters that may be causing issues.
My question is - will these changes flow through to the feature service, or will the FS remain static with the original schema that was generated on initial upload?
