Thank you for the great tool Larry.
Print Plus Widget Version 1.1.6 July 12, 2015
I am trying to use print plus tool with ArcGIS Server's print default print service. I am on Web AppBuilder 2.0. When I try to use scale slider to adjust the map extent for print out, the print output does not retain the map extent correctly. I have attached the screen shots to illustrate the problem. Not sure if it is a known issue or I have not configured the tool correctly.
Thank you,
