As part of my JavaScript App, using Web AppBuilder, I created two geoprocessing widgets. One allows the user to input a user defined area to calculate population density (Zonal Statistics as Table tool). After the tool has ran, the geoprocessing widget returns a table with the following fields:
Is it possible to configure the results to only display the SUM field? Something like "Total Population: [SUM]" in the results tab.
My other geoprocessing widget allows the user to input a user defined area to calculate the total number of structures within a given area (Spatial Join). The results are drawn on the map - making the user select the output polygon to retrieve the count total. Similar to my first question, is it possible to display the structure count within the geoprocessing results tab opposed to on the map within a polygon?
