I just got my Spike device, created a feature service, created a form from it and configured the form for use with Spike. I had no problem getting a Distance measure using the spike question type.
But, I have been unsuccessful measuring areas with the spike-full-measure question type.
I tried using the sample survey form, let it create a service and then tried to measure areas, still no success.
I am not getting any errors, no measurements are populated in the Survey 123 form.
Is this a hardware/software/version issue?
Survey 123 v 3.0.134
Spike v. 1.7.7(1004)
Android v 6.0.1
Tablet: ASUS Model P00l
Also, I noticed the sample survey form has some calculations using this syntax in the json pulldata -
Spike.objects.1.dimensions.0
and some using this syntax
Spike.objects[1].dimensions
Do both of these work?
Also in the blog post - https://community.esri.com/groups/survey123/blog/2018/03/06/using-spike-with-survey123-for-arcgis
The table describing standard tags populated by Spike has ImageDescription as imageDescription.
Sorry to throw all this out there.
Thanks!
-bert
