Hi, I am trying to create a pre fire plan survey for our local fire dept. (using non hosted feature service)
The surveyors would like to survey a building to collect information for a pre fire plan. And would like to fill out information for hydrants(question are in the survey), by clicking on the hydrants that are located near the building. I created a point survey feature class with required questions, used pull data function to pre populate hydrant information. they will put the hydrant no in the form and using pulldata, the rest of the information for that hydrant will be auto populated.
Instead of using Pulldata I would like to use a related table to store hydrant information and would like to prepopulate that table . Is there any way other than using Pull data function to perform this task? can a custom url be used to for this purpose? what would be the work follow? thanks for assisting.
Nusrat
