HI,
I have a strange phenomenon occuring
I have a calculation that used to work, is not being populated anymore.
I have a decimal field with a calculation. The following works:
${TOTAL_TRANSECT_LENGTH}*${DUB_CM_FOURTH}
The calculation is being performed using fields inside a repeat. the calculated field is outside that repeat.
when i substitute the above eqn for this:
pow(pi(),2)*sqrt(sum(${DUB_CM_FOURTH}))div(8*(sum(${TOTAL_TRANSECT_LENGTH})))*1.64
it does not work.
These eqns were working before.
i have attached the xlsform used to generate the survey.
cheers
