I published a survey about a month ago, based off an existing survey I previously published. I have checked all of the settings for both viewer and submitter (survey 123), they identical to the first survey's settings I published which works fine, the second survey however, viewers are unable to view the records (there should be 17 in total). I have noticed that in the folder on our portal in my content which the information is stored (feature class hosted & feature class ect) the feature class labeled stake_holder has no data but the feature class has data as apposed to the original survey its based on. Not sure if that has something to do with it or not since I am unaware of the stake_holders function. Can some explain whats going on.
thanks.
