I'm working on an Angular, Ionic, ESRI application that shows EV charge stations on a map. I have a view that displays the map with feature layer of charge stations. I have another view that displays a list of charge stations pulled from the graphics property of the feature layer.
My problem is that the list of charge stations is empty until the map view loads, because that's when the feature layer loads (using angular-esri directives). If I select the menu item to load the map view first, then navigate to the view that displays the charge station list, the list values are available and everything displays fine.
