Dear all,
I am trying to convert a shapfile with Geographic Coordinate System ITRF 2005 into WGS84 UTM 35S. I went through the following steps.
1. Open blank Arcmap
2. Set data frame to ITRF 2005
3. Added the XY Excel Coordinates to the map and then exported the events layer as ITRF 2005.
4. With the new ITRF 2005 Points shapefile, i use the project tool in data management toolbox to convert it from ITRF 2005 to WGS84 UTM Zone 35. I get the following error.
invalid extent for output coordinate system
Failed to execute (Project).
I also tried adding the ITRF 2005 Point Shapefile to a new data-frame that i set to WSG84 UTM Zone 35, and tried to export it to the coordinates of the data frame but still did not work.
