James Tedrick
I published a survey using S123 Connect (v3.1.126). Requirement is to use webform however the survey does not workvia the web app. It will work in the native application.
Getting error
Made sure to use the concat() function for calculating the geopoint location in the form.
Everything looks to be correct .Even have other forms that are formatted similar and working. Kind of stuck here. Please help.
Survey is attached.
