It seems that whenever I try to add a new field anywhere but the bottom of the sheet it will not change the schema of the feature service. It will show it on the form and in Connect but not in the attribute table or schema of the HFS. It seems to happen mostly inside a group tag. Last time I have to delete everything, copy the excel data to a new project, fix the excel list links (you should use ranges instead) then publish fresh.
This time I tried deleting the Hosted Feature Service and the code. Now the Survey123 site thinks it is gone but Connect still thinks it is there and will not republish. Just hangs on "Updating survey form package step".
Is there anyway to force it to rebuilt all the service end? Why can I not add a field after the fact? Do I have to start over yet again? If I have to start over how can I use the same name as before?
thanks
