Before I open a Case with ESRI technical support. I am curious if anyone else is having problem with Survey123 Build 3.7 (prob/maybe an issue on earlier versions) where a Photo Attached from the Camera Roll does not maintain the EXIF data when submitted through a Survey 123 (Mobile) on an iOS device?
Photos taken with the camera in Survey123 maintain their EXIF Data. Photos uploaded do not, unless they were captured in the Most Compatible Camera Format.
I've tested the image quite a few times using EXIF viewers on my phone. There is data there but when uploaded it gets stripped or removed. I haven't tried exporting from ArcPro/ArcMap using the attachment manager, this has mostly been though accessing it via Feature Service in AGOL. Then running it through a EXIF viewer software/website Jeffrey Friedl's Image Metadata Viewer that i've been using for years because i'm to lazy to install something on my computer. Perhaps I am missing something
You can view the feature service here (its all just test data), the most recent records are labeled as Missing Exif Data EXIF data 12/11/2019.
Device: iPhone 11 Pro Max (latest 13.2.3)
Survey123 Connect/Desktop: 3.7.60 builds (latest available)
Curious if anyone else could run a test or seen such a problem. Its possible that I might just be missing something in the attachment data. I had suspected it might have something to do with the zonkyness that comes with the HEIC to JPG conversions that occur automatically by iOS to ensure compatibility. Survey123 does not appear to honor the Camera Format setting.
I just tested by capturing a photo with Most Compatible (which creates the older JPG format). When uploaded to camera roll the EXIF is maintained. when uploaded using a photo in High Efficiency, the EXIF data is stripped. When a photo is taken with Survey123 Camera in HEIC mode. EXIF data is maintained. When attempting to take a photo with Most Compatible (Survey123 does not honor this setting and will always capture in HEIC format). Take a look at the last record in the feature service.
http://cdmsmith.maps.arcgis.com/home/item.html?id=6da1f6452b74432780425521cd7bdbbc#data
Curious if anyone else is seeing this.
