I have tried to create a report using the report dijit and keep getting the following error "Create widget error widgets/Report/Widget". I've explored the following example with no luck Create a custom widget using the Report dijit—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Below is my widget.js:
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'dojo/_base/declare'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/BaseWidget'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/dijit/Report'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/dijit/PageUtils'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>declare<SPAN class="punctuation token">,</SPAN> BaseWidget<SPAN class="punctuation token">,</SPAN> Report<SPAN class="punctuation token">,</SPAN> PageUtils<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//To create a widget, you need to derive from BaseWidget.</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">declare</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>BaseWidget<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// DemoWidget code goes here</SPAN>
<SPAN class="comment token">//please note that this property is be set
