I want to use optimized hot spot analysis in Arc GIS 10.3 for grouping of buildings in a particular area, say group of 32 or 64 buildings in each group, because of available splitting ratio of Power splitters in FTTB access networks.
I have two small questions:-
- From where i can get the geo database .gdb of these buildings in the selected area whom i want to cluster. Can i export the database from OSM (Open Street Map) or Google earth or parse the database in Matlab and import in ArcGIS.
- If i use Kmeans in Matlab, it does the clustering BUT i can't control the size of clusters (because of its inherent algorithm of cluster assignment and moving centroids steps) only thing which i can define is the total number of clusters required and the data set on which it should work.
