info it worked if it ends with ok
1 verbose cli [
1 verbose cli 'C:\\Program Files\\nodejs\\node.exe',
1 verbose cli 'C:\\ProgramData\\Microsoft\\VisualStudio\\MDA\\cba6b54a\\taco-toolset-6.3.1\\node_modules\\npm\\bin\\npm-cli.js',
1 verbose cli 'start'
1 verbose cli ]
2 info using npm@2.15.10
3 info using node@v14.5.0
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info prestart exb-server@0.1.0
6 info start exb-server@0.1.0
7 verbose unsafe-perm in lifecycle true
8 info exb-server@0.1.0 Failed to exec start script
9 verbose stack Error: exb-server@0.1.0 start: `cross-env NODE_ENV=production node src/server`
9 verbose stack Exit status 1
9 verbose stack at EventEmitter.<anonymous> (C:\ProgramData\Microsoft\VisualStudio\MDA\cba6b54a\taco-toolset-6.3.1\node_modules\npm\lib\utils\lifecycle.js:217:16)
9 verbose stack at EventEmitter.emit (events.js:314:20)
9 verbose stack at ChildProcess.<anonymous> (C:\ProgramData\Microsoft\VisualStudio\MDA\cba6b54a\taco-toolset-6.3.1\node_modules\npm\lib\utils\spawn.js:24:14)
9 verbose stack at ChildProcess.emit (events.js:314:20)
9 verbose stack at maybeClose (internal/child_process.js:1051:16)
9 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
10 verbose pkgid exb-server@0.1.0
11 verbose cwd C:\eb\server
12 error Windows_NT 10.0.18363
13 error argv "C:\\Program Files\\nodejs\\node.exe" "C:\\ProgramData\\Microsoft\\VisualStudio\\MDA\\cba6b54a\\taco-toolset-6.3.1\\node_modules\\npm\\bin\\npm-cli.js" "start"
14 error node v14.5.0
15 error npm v2.15.10
16 error code ELIFECYCLE
17 error exb-server@0.1.0 start: `cross-env NODE_ENV=production node src/server`
17 error Exit status 1
18 error Failed at the exb-server@0.1.0 start script 'cross-env NODE_ENV=production node src/server'.
18 error This is most likely a problem with the exb-server package,
18 error not with npm itself.
18 error Tell the author that this fails on your system:
18 error cross-env NODE_ENV=production node src/server
18 error You can get information on how to open an issue for this project with:
18 error npm bugs exb-server
18 error Or if that isn't available, you can get their info via:
18 error
18 error npm owner ls exb-server
18 error There is likely additional logging output above.
19 verbose exit [ 1, true ]
