I have built a Map Viewer application. I was hoping to test the rotation functionality of the navigation mode. This is a critical component of the application we need to develop, but I can not get this to work. I need the map to rotate with the direction of travel of the device . However when testing the application the map will only pan about the device location and will not rotate. I am testing the application on a Trimble Yuma device running windows 7 32 bit. I am sure that I am using the correct mode but I just can't seem to get the map to rotate. Is there an additional property that needs to be set for this to function ? This documentation indicates this is a feature of the map viewer. I'm relatively new to AppStudio, any assistance is appreciated.
