Where can I download SQL Server Client from. I need to make a database connection to our SDE connection and
I keep getting the error message.
'Failed to connect to the specified server. Connection was attempted with an older version of SQL Server Client communications software that is not supported.'
I googled this error message and there is a technical article which states you need to install SQL Server Client on your computer.
https://support.esri.com/en/technical-article/000010759
