Hi All,
I would like help/ideas on the following workflow. we have two people doing two separate parts of one survey (at same location) in a disconnected state at the same time. what would be the optimal solution to get the data together at the end of the day in the one survey? is there any behind the scenes wizardry that could / should happen. obviously only one of the locations could only be used which would be determined prior.
thanks for any ideas or suggestions.
