I am trying to run Raster Calculator in Model Builder, however I am getting what looks like two errors after my model reaches a certain step. I'm not sure if it is a syntax issue or something else.. Raster Calculator is used in earlier steps in the same model with no problem. Could someone please help with my syntax? Below is what I wrote:
(Power("%P95%"-"%Ia%"*"%S05g%",2)) /("%P95%"+(0.95*"%S05g%"))
Note: P95 and Ia are parameters, and S05g is a dataset raster that is calculated in the previous step.
I then get this error message:
ERROR 000539: Error running expression: rcexec() Traceback (most recent call last): File "<expression>", line 1, in <module> File "<string>", line 5, in rcexec File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4485, in Times in_raster_or_constant2) File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Utils.py", line 53, in swapper result = wrapper(*args, **kwargs) File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4482, in Wrapper ["Times", in_raster_or_constant1, in_raster_or_constant2])RuntimeError: ERROR 000732: Input Raster: Dataset 0.05 does not exist or is not supported
Failed to execute (calculate Q95g).
What's going on here? I originally wrote the expression with '**' instead of 'Power(,)', but that also presented me with the same error. I am using ArcGIS Pro 2.0 if that helps.
Thanks!
