I have inserted a custom button (FilterRows) into the right click context menu of a table cell as below.
<SPAN class="operator token"><</SPAN>updateModule refID<SPAN class="operator token">=</SPAN><SPAN class="string token">"esri_editing_EditingModule"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>menus<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>updateMenu refID<SPAN class="operator token">=</SPAN><SPAN class="string token">"esri_editing_tableCellContextMenu"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>insertButton refID<SPAN class="operator token">=</SPAN><SPAN class="string token">"FilterRows"</SPAN> separator<SPAN class="operator token">=</SPAN><SPAN class="string token">"true"</SPAN> insert<SPAN class="operator token">=</SPAN><SPAN class="string token">"after"</SPAN>
placeWith<SPAN class="operator token">=</SPAN><SPAN class="string token">"esri_editing_tableCopyCellButton"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>updateMenu<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>menus<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>updateModule<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I need to retrieve the value of the cell that the user right clicked on. I suspect that I need to retrieve the TableControl that the user clicked on and retrieve the cell value that way. But how do I retrieve the TableControl? Uma Harano Wolfgang Kaiser
