I am working on an app to compare two maps on our portal. I will later use this app in a StoryMap.
I have this results for now using the portal app template:
When I displayed this app in the story map, or even as the app itself, there is this small buttons called "toogle map info" that are showing the dirty legend of the map... Is it possible to remove this buttons using css? For now I did not find the solution..
Thank you!
