Dear All
Hope You all are fine..
Im facing an issue with the conversion from cad to gis ..
The issue is
- Annotation of Pipes are not being joined after the conversions .
Process followed
- Created an empty GDB
- Exported the selected layers of pipes which are mentioned as " DI Line , DI Text and old line Layers of cad file if available , These are pipe lines and converted to GDB then defined projection and trying to do spatial join. The dimension which are Diameters of pipes are not being taken and symbols are being taken..
Before exporting i tried convert to text in autocad for the drawing dimension then taken to Gis , as Yousef told me to do , Even though i failed.
