I have a form that crashes shortly after opening in the Survey123 app for iOS. I have been able to diagnose the two causes but am unsure how to fix them. I've read in other posts that having too many values in the relevant field will cause it to crash. This is true for my form. Has a fix been found for this issue?
I've also discovered that the calculations in the form to convert DD to DMS causes it to crash as well. The calculations come from the post Declining Decimal Degrees in Survey123. These calculations are needed so the DMS coordinates are properly formatted for the feature report generated on the back end. It almost seems like the calculations are too much for the app to handle, but the same form works wonderfully on the Android version.
Additionally, the survey was created and published in Survey123 Connect version 3.5.
