I am converting points to raster and have to match the converted points to a raster image. In converting the points to raster i set the environment to snap to the existing raster and used same cell size and coordinates. However the output is showing raster cells which are slightly displaced, about 3mm displacement. How do i reset the snap so the two cells match exactly? I have tried working both in a gdb environment and outside it but just a slight improvement with the gdb environment. The displacement this time is in one direction, to the North. i am
