Hi all,
I'm exporting data (using Creating LiDAR-Based Heightmaps in Unity 3D (Using ArcGIS) - YouTube ) for guidance.
I've imported in LAS data as a LAS dataset, then am using some of the filtered ground points and the tools "LAS Dataset to Raster" (found through the search feature in the right pane) to rasterize filtered ground points and create a raster heightmap.
When I right click the newly created raster heightmap under Layers and go "Data -> Export Data" and check off using the rendered, there's no option for me to change the format from a "File Geodatabase" to something like PNG. I also can't find the file that is created.
