Using following ArcPy snippet, I am able to get Extent of current map
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping
<SPAN class="comment token">## Sets the MXD file </SPAN>
IMXD <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">## Sets the Dataframe </SPAN>
DF <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>IMXD<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Layers"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">print</SPAN> DF<SPAN class="punctuation token">.</SPAN>extent <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
