Hello, I am quite new to using python, but...I have a set of overlapping polygons that I would like to use to clip several raster layersI have the following code thus farimport arcpy # set environments arcpy.env.workspace = "Path" arcpy.env.overwriteOutput = True #set parameters featureTable="Individual_catchments" baseFeature="elevation" #set cursor rows = arcpy.SearchCursor(featureClass) # loop for row in rows: #here I select the geometry feat = row.Shape arcpy.Clip_management(baseFeature, "#", "catch"+str(row.Local)+".tif",feat, "0", "ClippingGeometry")
however, when I try to run I get an error stating "ERROR 999999: Error executing function. Raster dataset already exists Failed to execute (Clip). "thank you for your time and helpcheersMat
