I am using the single line World Locator. I like that it works for both either a full address (310 W High St, Jefferson City, MO 65101) or just a city name (Jefferson City, MO). Since I am working with data specific to Missouri, I've been asked to make this more user friendly and somehow programmatically manage adding MO at the end of a city name if the user doesn't specify.I didn't think this would be a problem. I have an inputText field, textAddress and I'm defining the input address as the value in it. var inputAddress = { "SingleLine" : dojo.byId("txtAddress").value };In Firebug, it says inputAddress is [object Object], but I can examine the value of SingleLine and see what I entered.Next I check to see if inputAddress already has the Missouri prefix, MO, at the end of the string:var checkMO = inputAddress.SingleLine.slice(-2).toUpperCase(); if ( checkMO !== 'MO' ) { console.log("not MO"); inputAddress = inputAddress.SingleLine + ", MO"; console.log(inputAddress); }else { console.log(inputAddress.SingleLine + " has MO"); }Then I pass inputAddress to the locator:locator.outSpatialReference = map.spatialReference; var options = { address : inputAddress, outFields : ["*"] }; locator.addressToLocations(inputAddress); }This doesn't work. I think it is because inputAddress starts out as an object and I'm trying to deal with a string. I tried inputAddress + ", MO" instead of inputAddress.SingleLine + ", MO", but neither seems to work. Instead the locator says it found no matches. I can see that the inputAddress looks OK in the console window. Could someone explain what's wrong with my logic and/or provide a workaround to this?
