Hi
I'm developing a model which uses the select data tool and am trying to find a way to use this to iterate through a feature dataset. I'm stuck because the child data element does not seem to accept a variable such as %Name% only accepting a single feature class in the feature dataset.
Is there a simple way of performing this procedure or is it not possible to do this?
I've attached a jpg of the model to this message which hopefully shows what I am trying to do - iterate through a feature dataset to
a) select adjacent polygons
b) merge the adjacent polygons to the original feature class
The %name% variable is used so that the same feature class is selected for each iteration.
Hopefully someone can help!
