HiI'm new to phyton and need to convert a bunch of dababase files to shapefiles. I have a batch processing code which is working fine. However, after a while it gets incredibly slow and takes more than an hour for something it took only 10 minutes at the start. I guess that it's somehow a memory - related problem.Anybody an idea how to clear memory or otherwise fasten the program?Here is the code:
import arcpy
from arcpy import env
import os
# Set the workspace for the ListFiles function
env.workspace = "g:/CAPAS_Data/N50/"
# Use the ListFile function to return a list
ListDatabase = arcpy.ListFiles("*.mdb")
# print ListDatabase
for x in ListDatabase:
env.workspace = "g:/CAPAS_Data/N50/"+x
ListDatasets = arcpy.ListDatasets()
for y in ListDatasets:
env.workspace = "g:/CAPAS_Data/N50/"+x+"/"+y
ListClasses = arcpy.ListFeatureClasses()
for z in ListClasses:
inFeature =
inFeature_str = str(inFeature)
outLocation= "g:/CAPAS_Data/shapefiles/"+inFeature_str[3:-2]+"/"
if not os.path.exists(outLocation):
os.makedirs(outLocation)
arcpy.FeatureClassToShapefile_conversion(inFeature, outLocation)
Thanks for any help!Corinne
