I'd like to query content according to a spatial relationship using ArcGIS API 4.12. I've set up a test of this query as follows:
<SPAN class="keyword token">var</SPAN> municBoundariesURL <SPAN class="operator token">=</SPAN> <SPAN class="string token">"https://devarcgisent.placeholdertext.lan/serverdev/rest/services/ParkFinder/MunicipalBoundaries2/MapServer/0"</SPAN>
<SPAN class="keyword token">var</SPAN> queryOptions <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//where: "1=1",</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
returnGeometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
spatialRelationship<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"within"</SPAN><SPAN class="punctuation token">,</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"-83.04517899999858,42.32973669999929"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> municBoundariesURL
queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>queryOptions<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> nameResults <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
feature<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">=</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>NAME
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I know this isn't set up correctly, but I played with a number of configurations and every time I got a message in the console saying: "[esri.core.Accessor] Accessor#set Invalid property value, value needs to be one of 'esri.geometry.Extent', 'esri.geometry.Multipoint', 'esri.geometry.Point', 'esri.geometry.Polyline', 'esri.geometry.Polygon', or a plain object that can autocast (having .type = 'extent', 'multipoint', 'point', 'polyline', 'polygon')"
The heart of my question boils down to lines 2-7 above. I can successfully search by field name (ie, set 'where' equal to "1=1" or any other field name), so I know the query is working when the query options are populated properly.
Can someone help me to set up the query options so that I can return just the feature that the point (specified with 'geometry') falls within?
Thank you
