Hello R&H Users
We have discovered a different behavior between linear referencing in R&H.
Our data model is based on road axes. The direction of linear referencing is predefined.
Most of the axis are straight and the linear referencing works perfectly in R&H. But some of them have ramps intersecting the axis. These ones are not correctly referenced in R&H. The only way to do this is to set the M-values manually. However, these values are lost after using R&H, for example after realigning the axes.
Did you encounter this problem too? If so, what was your way to solve it?
